Replacing seal on fromt pto shaft on JD 855
   / Replacing seal on fromt pto shaft on JD 855 #1
DB43023
Granville, Ohio
JD 855
Does anyone know how to replace the fromt pto seal on a JD 855? By looking at I can't tell if I have to take the rearend apart or if there is an easier way.
Thanks.
DB43023
That should read front pto shaft.
   / Replacing seal on fromt pto shaft on JD 855 #3
From the FSM, I assume you mean the mid pto.
The transaxle front cover must be removed for the
following seal replacement:
• Mid PTO Drive Shaft Seal (M800600).
Yes, I do mean the mid pto. Thanks for your reply. That's what I was afraid of.
   / Replacing seal on fromt pto shaft on JD 855 #5
I didn't see anything more about the job in my quick glance.
Thanks for your follow up. Since my original post I have gotten a technical manual and it looks like I have to do quite a bit to get the front cover of the transaxle off to get to the seal. $5.00 part but several hours labor.
   / Replacing seal on fromt pto shaft on JD 855 #7
Isn't that often the case? Part is cheap but the time it takes to get to it....
I really need to get working lights on my other tractor so that I may pull the 855 out of service for a while. Lots to do on it and it's too important to have down for any length of time.
   / Replacing seal on fromt pto shaft on JD 855 #8
Hi, Where you able to get the job done? I have the same issue with a 855 a just purchased. Did you have any give in the mid PTO when it leaked? Any info on how the job went would help.
Thanks,
Josh
John Deere 4640 Tractor (A50514)
John Deere 4640...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
1272 (A50490)
1272 (A50490)
John Deere HPX Gator (A50514)
John Deere HPX...
2013 RAM 4500 (A50323)
2010 Nissan Rogue SUV (A50324)
2010 Nissan Rogue...
