Replacing rubber boot on the front shaft
/ Replacing rubber boot on the front shaft #1
sonofczechgun
Old Dominion
B1750HST 4WD
greetings. I got a new boot for the front shaft from Tractorsmart but I can not figure out how to replace it.
I have to disconnect the shaft somewhere, but all the u-joints seem to be pressed on. Any idea anybody?
Thank you
Oh, it is for B1750 4x4 with HDST, thanks
/ Replacing rubber boot on the front shaft #2
Which front shaft are you referring too? /forums/images/graemlins/confused.gif
Front drive Shaft?
Front steering?
/ Replacing rubber boot on the front shaft #4
When you slide the cover back you should see the U-joint. There should be split pin(s) (roll pins) holding the U-joint assembly on the input shaft of the front axle. Remove the pins and shaft should slide off. I am looking at a B24-27-2910 WSM. I believe they are similar to your 1750. Rear or transmission end should have similar pins.
Kenworth T6 (A63688)
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63688)
Magnolia Trailer...
2022 EZ-GO ELITE...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
