Replacing rubber boot on the front shaft
/ Replacing rubber boot on the front shaft #1
sonofczechgun
Old Dominion
B1750HST 4WD
greetings. I got a new boot for the front shaft from Tractorsmart but I can not figure out how to replace it.
I have to disconnect the shaft somewhere, but all the u-joints seem to be pressed on. Any idea anybody?
Thank you
Oh, it is for B1750 4x4 with HDST, thanks
/ Replacing rubber boot on the front shaft #2
Which front shaft are you referring too? /forums/images/graemlins/confused.gif
Front drive Shaft?
Front steering?
/ Replacing rubber boot on the front shaft #4
When you slide the cover back you should see the U-joint. There should be split pin(s) (roll pins) holding the U-joint assembly on the input shaft of the front axle. Remove the pins and shaft should slide off. I am looking at a B24-27-2910 WSM. I believe they are similar to your 1750. Rear or transmission end should have similar pins.
HYSTER H80XM STRAIGHT MAST FORKLIFT (A64279)
HYSTER H80XM...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2003 Ford Ranger Pickup Truck (A61573)
2003 Ford Ranger...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
