Tires Replacing rear turf tires on jd 855
   / Replacing rear turf tires on jd 855 #1
kimodc
My tractor is in need of some new "shoes." I was able to buy a new set of Carlisle multi-tracs for the front (23x8.50x12) but Carlisle does not make the multi tracs for the rear 33x12.50x15. Has anyone else ran into this problem? I can't seem to find any turf tires for the rear the size I need. Any help would be appreciated.
Thanks,
Kim
   / Replacing rear turf tires on jd 855 #2
I was searching for stuff on Machinefinder this evening and think I remember see a set of takeoffs for an 855, might want to check that out.
Steve
   / Replacing rear turf tires on jd 855 #3
I use the same size turf tires as your 855. While I don't need new ones yet, I have researched a few times to see what is available. Just as you found, there are many options from different manufacturers for the front tires, even R4s. The rears are a different story as no one seems to make that size. This is no help to you, but I'll be interested to see if someone else comes up with something.
   / Replacing rear turf tires on jd 855 #4
FWIW, you might look into light truck tires. This is the size I'll put on my Jeep if I ever get it back together. Perhaps an all-terrain in that size might work?
And the rear tires on my 855 are also quite worn...
I did a little more searching and found that goodyear does still make a 33" softrac....at $360 a piece! ...plus shipping. Instead I ordered some new 36" multi-trac blems for $125 a piece shipped. Since mine is a 2wd I am not as worried about matching up with the fronts. 36" tires were an option for the 855, but you cannot use a 72" mmm with them.
   / Replacing rear turf tires on jd 855 #6
I think I saw your post. And $360 per tire is a bit nuts. But as I have 4wd on mine, adding a couple inches to the rear tire size isn't an option. Plus, I have a 72" mower which I use weekly during the summer.
So I must keep the eyes open for opptions. Light truck tires may end up being what I do. Unless I find some used tires. That's kind of what I hope for. Dream for.
   / Replacing rear turf tires on jd 855 #7
And today I discovered that one of those rare R3 tires my tractor uses appears to have a puncture somewhere due to being so worn down.
Just don't have the cash to buy new tures and have them mounted/filled. May keep the R4's on over the summer.
   / Replacing rear turf tires on jd 855 #9
I found a set of good used Good used 90% tread Good Year Turf tires 33x12.5x15 mount on wheels(looked like JD pattern) they were painted orange (They said Kubota) Front rims had a different bolt pattern then front JD , but they were also in great shape 23x8.50x12 carlisles these were at Weavers Compact Tractor parts in Shippenesburg PA , they advertise in Tractor House, I dont know what they want for them but they were in great shape!
   / Replacing rear turf tires on jd 855 #10
Hey Kimodc,
Would you mind to tell me where you got your blems. I have been pushing off buying for the same reason. I have done quite a bit of looking and the best I found was my JD dealer (believe it or not!) at 275 each. Too much and so if I can find another set of blems like yours, my 855 might have some new shoes to take on the lawn this spring.
Thanks,
Phil
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
20305 (A51694)
20305 (A51694)
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2012 WESTERN STAR 4900 SB (A52472)
2012 WESTERN STAR...
INSPECTION (A51573)
INSPECTION (A51573)
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
