Masempine
I thought a new thread might be in order. Much info about leaking fluid and oil seal repair on the other thread
Orbitrol valve cost : $1140. Remove steering wheel using puller with bearing puller adapter. Cost $50 from Lowes. Option: drill holes in SW hub to avoid adapter collar. Mark hoses R, P, T, L based on legend on bottom of PSU. Loosen hose connections. Will help to remove as much hardware as possible to lessen fight. 3/4" for hose connector. 11/16" for nut at bottom of PSU. More to follow
