Replacing piston rings
   / Replacing piston rings #1
IH_4_Me
New Zealand
IH 574
Hey guys,
Is it possible to replace the piston rings in a tractor engine without having to separate it from the gearbox? i.e. having to break the tractor in half to split the engine open. I have rebuilt smaller engines from frame type vehicles where the engine is easily removed and put back in but a tractor is is different story, with the engine being part of the frame itself.
Thanks for your help
   / Replacing piston rings #2
Yes, if you can remove the cylinder head and oil pan.
   / Replacing piston rings #3
We did it on a Fergie TO-20 without a problem. The biggest concern is getting the oil pan gasket back together correctly and all that takes is a bit of care. It will all depend on your model of tractor and whether the oil pan is part of the frame.
   / Replacing piston rings #4
Did it with an old Allis Chalmers WD with no problem. I guess it would depend on your access to the crankshaft.
   / Replacing piston rings #5
It can be done on most tractors, however, splitting a tractor in half is not hard, and does not take long. Once split the rest is a cake walk.
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
Light Tower (A52377)
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
CAT CS563 (A47477)
CAT CS563 (A47477)
2018 FREIGHTLINER CASCADIA SLEEPER (A54313)
2018 FREIGHTLINER...
Park Dump Trailer (A52377)
Park Dump Trailer...
