Replacing O-rings
/ Replacing O-rings #1
jba3520
Eatonville, WA
JD 3520
I'm in the process of installing a diverter valve on my JD 3520 and the instructions call for me to replace the O-rings on the adapters going into the control valve. This tractor has less than 50 hours on it and I'm wondering if I really need to replace them? Are they saying to replace them because I have had to disassemble it? ... just a good idea?... or what? Will my hydraulics leak prematurely if I reuse the O-rings?
/ Replacing O-rings #2
Reguardless of the specific reason.. ( like a crush/deforem issue ).
How much do the new orings cost, vs the time it will take you to take it apart and fix if they start leaking later?
Soundguy
/ Replacing O-rings #3
I work with high vacuum chambers in which there are many O-rings. I always change O-rings any time they are removed. The cost of an O-ring vs. the trouble of a leak is small.
When you install new O-rings make sure all the surfaces it contacts are clean and put a little vasoline or hydraulic oil on the ring before reassemble. A dry O-ring could get cut or twisted upon reassembly.
You'll feel better about changing the O-rings when the jobs done and there are no leaks.
Randy
CATERPILLAR 316FL EXCAVATOR (A65053)
CATERPILLAR 316FL...
Rhino HPHD (A64127)
Rhino HPHD (A64127)
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2012 Mack CHU613 Truck, VIN # 1M1AN09Y6CM010558 (A65563)
2012 Mack CHU613...
