Replacing O-rings
   / Replacing O-rings #1
jba3520
Bronze Member
Eatonville, WA
JD 3520
I'm in the process of installing a diverter valve on my JD 3520 and the instructions call for me to replace the O-rings on the adapters going into the control valve. This tractor has less than 50 hours on it and I'm wondering if I really need to replace them? Are they saying to replace them because I have had to disassemble it? ... just a good idea?... or what? Will my hydraulics leak prematurely if I reuse the O-rings?
   / Replacing O-rings #2
Reguardless of the specific reason.. ( like a crush/deforem issue ).
How much do the new orings cost, vs the time it will take you to take it apart and fix if they start leaking later?
Soundguy
   / Replacing O-rings #3
I work with high vacuum chambers in which there are many O-rings. I always change O-rings any time they are removed. The cost of an O-ring vs. the trouble of a leak is small.
When you install new O-rings make sure all the surfaces it contacts are clean and put a little vasoline or hydraulic oil on the ring before reassemble. A dry O-ring could get cut or twisted upon reassembly.
You'll feel better about changing the O-rings when the jobs done and there are no leaks.
Randy
2006 Volvo VNL (A52748)
2006 Volvo VNL...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52748)
2019 Tico Yard...
