Replacing Logging Winch Cable
   / Replacing Logging Winch Cable #1
BILLWEST
I have a fransgard winch and need to replace the cable. I am not sure how to get the old off the drum and attach a new one. Anyone have experience with this? I can open the access plate but i just cant see how its attached in there. Must be a simple answer - thanks.
   / Replacing Logging Winch Cable #2
I think if you pull unwind the cable it will becoem obvious. I suspect if it's liek the ones I have changed it's a keyhole that the ferell on the end of the cable clips into.
Andy
I have unwound it all the way and taken off the plate which I believe is all you need in order to access the inside of the drum. It appears the cable tightly wraps 180 degrees around something and of course is tighter than heck and its not possible to just push it backwards with your hand. SO I am hesitant to just start banging on it with a rod or something until I ask a few who may have done it. thanks
   / Replacing Logging Winch Cable #4
I am not familar with your winch, but I have had to take a torch and cut the dead head end at the winch, just watch out, be careful. Usually after you cut the cable, you can tell how it goes back.
Good Luck
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2015 Chevrolet Silverado 2500HD (A52128)
2015 Chevrolet...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
