Replacing Hydraulic Line-JD 3320
   / Replacing Hydraulic Line-JD 3320 #1
gonnabe
John Deere 3320
Hi all- I'm new here so please be patient with me.
I have a 2006 John Deere 3320 (300 hours). The quick connect bracket for the front bucket has been bent downward and now it appears the fitting/line two out from the tractor frame is leaking.
It looks as if it is the hydraulic line and not the connection as the fluid leaks along the rigid tubing, like perhaps the tubing is cracked. Problem occured earlier this year and is getting continually worse to the point fluid shoots out when the front bucket is moved.
I am looking for guidance on how best to disassemble the machine to replace the line (or to test the line). To my untrained eye it appears I must disassemble the quick connects in sequence to break the system apart at the front of the tractor. Then it looks like I would need to remove the right rear tire and fender to access the rear of the hydraulic line.
Does anyone know if this is accurate or is there an easier, more direct way to replace the part? Better yet, is there an effective way to verify what/where the leak is prior to complete disassembly? Once the machine is apart, what else should I do as maintenance while I'm there?
I Thank you in adcvance for the help.
   / Replacing Hydraulic Line-JD 3320 #2
I know this an old thread, but does anyone have insight on the question above? I'm in the same situation now and need to replace the 4 hard lines. Mine have rusted out and started to leak. Looking for guidance on where these attach in the rear of the tractor. Can't see where they go, but I haven't started taking the tractor apart yet either. Looks like I need to start by removing the right rear tire and work my way in from there, but not sure.
2012 Audi Q7 AWD SUV (A50324)
2012 Audi Q7 AWD...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
CFG Industrial QK18R (A50121)
CFG Industrial...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A50322)
2015 John Deere...
19101 (A51694)
19101 (A51694)
Terry 12ft Aluminum Jonboat (A50324)
Terry 12ft...
