Replacing Ford loader control valve on Ford 1700
   / Replacing Ford loader control valve on Ford 1700 #1
BenL
Ohiopyle, PA
Ford 1700
I am looking at a Ford 1700 that has a FEL, structurally everything seems solid although most of the paint is gone but it looks like a Ford 770. The loader needs hooked up and the lines need replaced from the 2 lever control valve to the loader. Fittings are fairly rusted at the control valve, someone just cut the lines when they took it off, I am assuming they decided not to mess with getting the lines loose. The levers are free both ways on the control valve but I am thinking of replacing it with a 2 spool joystick loader valve while I am at it. New to tractors so I cannot seem to find what GPM I would need on the control valve to price for sure, something that is like 13gpm or 25gpm. I did not know if more gpm is better or worse for a smaller tractor like the 1700.
   / Replacing Ford loader control valve on Ford 1700 #2
13 GPM should be fine for that tractor.
I don't know what the pump output is in GPM, but I am sure for a tractor that size, a 13 GPM valve is very satisfactory.
   / Replacing Ford loader control valve on Ford 1700 #5
The one issue when buying a loader valve is do you need or will you want in the future to have a power beyond feature.
The "Do you need" question is answered by the number of lines on the existing valve. 6 and it is not using power beyond. 7 and power beyond is essential.
Many valves can be easily converted to power beyond by use of a special sleeve or plug.
If you do not need PB now but might in the future, buy a valve with the feature and also the special sleeve or plug but then do not install the PB stuff now.
Finding the appropriate sleeve or plug at a future date can be difficult and the cost for the sleeve or plug is usually less that $50.
Dave M7040
   / Replacing Ford loader control valve on Ford 1700 #6
Also do you want float? Not all valves are created equal.
   / Replacing Ford loader control valve on Ford 1700 #8
The GPM is not listed in the specs noted above. I would be surprised if it was more than 4-5 GPM. Remember, that's only a 2-cylider 20hp tractor. See if there's a block off plate on the left side of the engine. Ford put those on tractors to run a secondary pump. The pumps are a little pricey because they're gear driven but it's a pretty simple add-on. You'll just have to make sure you can supply it with enough hydraulic oil. Some FELs use the towers for oil tanks.
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
Little Giant Poly Water Tank (A50515)
Little Giant Poly...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52141)
2015 FREIGHTLINER...
New Holland B95 Backhoe (A50490)
New Holland B95...
BRUSH HOG 2615 - 15' BATWING MOWER (A51243)
BRUSH HOG 2615 -...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
