Replacing fogged double pane glass
   / Replacing fogged double pane glass #1
Paddy
Bloomington, IN
Kubota, G5200, KAMA 454
The fun continues as I prep my home for sale. My 1985 Kobe & Kolbe windows have leaked to a point where 90% of them look bad on cold days. I need to something about this. There are 10 double hung windows, (20 sashes)
Options:
1 Replace complete sash set(2), frame stays but buy K&K replacement wood framed section with glass. $250 a pair. The wood frames need to be painted and varnished. 10 year warentee ($2500)
2 I Replace the glass. glass will be $80 per pair. The panes are beded in silicon and trimed with a plastic molding. I will likely have to replace plastic trim as well, so might figure $100 per pair ($1000)
3 Same as above, but have the glass shop do the install labor. ($1000 + labor??)
5 year warentee
Has anyone done this?? Not sure how bad cutting the window out of the silicon bed will be
   / Replacing fogged double pane glass #2
I would try glass only and order new glazing bead from K&K for one only and see how bad it is.
Shvl73,
OK, I gave one a try. Well I removed the plastic trim, 2 of 4 pc. I cracked both at the ends getting it started. Then a took a new razor and from the inside, slid down the wood/glass contact area breaking the bond. Looks like it won't be to bad getting the glass seperated from the wood.
If I can get the plastic trim, I think I can replace the glass pretty easy.
   / Replacing fogged double pane glass #4
OK, I must be missing something here. Isn't there a vacuum pulled between the panes? Or a nitrogen purge? What prevents them from fogging between the panes?
Gsganzer,
They loose their seal between the two "pains". Mine had a 10 year warrentee and started to fail at....10.5 years!!
Moisture gets in and condences creating the nice fog look :(
   / Replacing fogged double pane glass #6
I've read about a process to reseal the windows without taking them out. I've also see signs advertising businesses that do it. I haven't tried it yet but intend to investigate them in the near future. I have close to 50 4'x6' panels and it costs about $700 per panel to have them replaced with new sealed units. I usually have to replace at least 2-3 a year. If they can be resealed for $200-300 per panel, its a good deal, even if the resealing on lasts 5 years.
Howard,
I would have a couple concerns with resealing. One, the water etches the glass in a short time. So I'm not sure how they could clean/re-seal them in place. I would guess they could be dissasembled on site, cleaned, evacuated/gassed and then sealed. I have a freind who tried making a double pain. He clains it's still holding a seal via, it's not foged up.
If I were you I would re-evaluate the savings of using double pain. At $2100 per year in replacements, it can't be cost efective. Or You might consider finding a "life time warrentee"
I thought my issue was big, geez!
   / Replacing fogged double pane glass #8
My father in-law just reglazed their kitchen casement. His wasn't clad however, so he just made new wood glazing bead.
   / Replacing fogged double pane glass #9
Wow! very pricey, I hit a 4' wide patio door with a rock thrown from a weedeater and put a hole in it. It has a 1" space between glass and it was only a little over $300 for them to come replace it. John J
   / Replacing fogged double pane glass #10
I just replaced 4 existing windows with Certainteed New Castle XT vinyl, 3 double sliders and a double hung. The windows are double paned, insulated, argon gas filled and "Thermalflect" (Low-E)
Certainteed has a lifetime, warranty that protects frames, sashes, panels, hardware and glass for as long as you own your home. (The warranty can be transferred to a subsequent owner and will be 20 years for material and 5 years for labor from the original date of installation.)
2430 (A51248)
2430 (A51248)
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
2013 FREIGHTLINER CASCADIA DUMP TRUCK (A54313)
2013 FREIGHTLINER...
