Replacing engine Coolant on B2620
   / Replacing engine Coolant on B2620 #1
Amateur
Chambly, Quebec, Canada
Kubota B2620 HSD
Hi, I want to replace mu engine coolant and I am not sure what to use. I just buy this engine coolant (Zerex Pre-Charged Antifreeze/Coolant) and I want to know If it is what I need. I have a b2620.
Thanks.
:confused:
Zerex Pre-Charged Antifreeze/:confused:
Protects diesel engines from rust and corrosion and cylinder liners from liner pitting and cavitation
   / Replacing engine Coolant on B2620 #2
50/50 mixture ethylene glycol and water. Which is in most antifreeze that i know. I use Prestone.
   / Replacing engine Coolant on B2620 #4
The Zerex will be fine for your tractor,although a little overkill.Your Kubota engine does not have cylinder liners so the liner protection is not needed.Regular old green coolant mixed 50/50 with distilled water would match the factory fill-renew every two years.Good Luck!
2017 Ford Taurus SEL Sedan (A46684)
2017 Ford Taurus...
Pull Type Pro Series Reel Mower (A49339)
Pull Type Pro...
SPRINKLER TRAILER (A48992)
SPRINKLER TRAILER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
2011 GMC Acadia SLT2 SUV (A46684)
2011 GMC Acadia...
2025 JMR Tree Boom Skid Steer Attachment (A46683)
2025 JMR Tree Boom...
