Replacing clutch on 6500 4WD...
   / Replacing clutch on 6500 4WD... #1
tholder85
Mahindra 6500 4wd
I am about to replace the clutch on my 6500 as it is slipping really bad from forth gear on up. My question is about the Service Manual for the 6500, would it have any info that would benefit me on this job or is it a waste of money? I have split a couple older Fords and helped with clutch jobs on them, so I at least have a little knowledge, in general. TIA!
   / Replacing clutch on 6500 4WD... #2
Typically some torque specs and exploded views. Maybe a little beyond that. But overall it’s not like a factory car manual.
   / Replacing clutch on 6500 4WD... #3
I'd be interested to see how this goes if you could share images of the project.
   / Replacing clutch on 6500 4WD... #4
Might need some specs. My 4110 has adjustable fingers on the pressure plate and you have to know the spec and where to measure for the installed height. I have to remove the flywheel and do it on a bench using a "special" tool I made up. Kinda hard to reach the flywheel surface to measure with the disc installed. But as far as just doing the split the manual probably won't help a lot.
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
Takeuchi TL150 (A50120)
Takeuchi TL150...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
