Replacing clutch on 6500 4WD...
   / Replacing clutch on 6500 4WD... #1
tholder85
Mahindra 6500 4wd
I am about to replace the clutch on my 6500 as it is slipping really bad from forth gear on up. My question is about the Service Manual for the 6500, would it have any info that would benefit me on this job or is it a waste of money? I have split a couple older Fords and helped with clutch jobs on them, so I at least have a little knowledge, in general. TIA!
   / Replacing clutch on 6500 4WD... #2
Typically some torque specs and exploded views. Maybe a little beyond that. But overall it’s not like a factory car manual.
   / Replacing clutch on 6500 4WD... #3
I'd be interested to see how this goes if you could share images of the project.
   / Replacing clutch on 6500 4WD... #4
Might need some specs. My 4110 has adjustable fingers on the pressure plate and you have to know the spec and where to measure for the installed height. I have to remove the flywheel and do it on a bench using a "special" tool I made up. Kinda hard to reach the flywheel surface to measure with the disc installed. But as far as just doing the split the manual probably won't help a lot.
2011 Chevrolet Avalanche LTZ Crew Cab Pickup Truck (A50323)
2011 Chevrolet...
John Deere Z994R (A50121)
John Deere Z994R...
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
2023 Electric Intimidator (A50514)
2023 Electric...
