Replacing bottom part of the lift rod on an l3800
   / Replacing bottom part of the lift rod on an l3800 #1
mi462478547
Hudson
Kubota
Has anyone replaced the bottom part of the adjustable lift rod on an L3800 3?point? I bent the lower portion that screws in for adjustment. Messicks sells this part. I bought it. It looks from the parts diagramed this lower portion is pinned in. I need to remove the old bent lower portion. Anyone done this?
Thanks
Images of bent lift rod and parts diagram from Messick’s related to question above.
L
These are images related to the question above.
   / Replacing bottom part of the lift rod on an l3800 #4
Yea, so the threads of your lift arm are bad... Look on the diagram from Messick, #70 I think is a screw, then you need to punch out #40, spring pin (or rolled pin).
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
2020 BOBCAT T76 R-SERIES SKID STEER (A51246)
2020 BOBCAT T76...
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
7022 (A50322)
7022 (A50322)
2020 JOHN DEERE R4023 LOT IDENTIFIER 87 (A53084)
2020 JOHN DEERE...
