Replacing B2400 3pt sway links w/B27/2910 links
   / Replacing B2400 3pt sway links w/B27/2910 links #1
rick_m
Has anyone tried to replace their existing B2400 anti-sway links with the new links designed for the B2710 / B2910? They look like a direct replacement, and they appear to be a better design than the turnbuckle. Any thoughts / comments are appreciated.
Thanks,
Rick
   / Replacing B2400 3pt sway links w/B27/2910 links #2
Re: Replacing B2400 3pt sway links w/B27/2910 link
Some of the parts are interchangable. I wrote to Carver and asked for a quote for the parts, but never got a final answer. My local guy says the parts are about $350.
For my money I'll continue to turn the buckle.There are some differances in the way the link arms connect.
   / Replacing B2400 3pt sway links w/B27/2910 links #3
have not seen those, but i thought the turnbuckels were pretty easy to adjust.
   / Replacing B2400 3pt sway links w/B27/2910 links #4
The real advantage is the ratchet leveling adjuster. I am sure that part can be retrofit to other models. Some creative thinking has produced a solution for the lower arms as well. But the cost is just too high for me considering what I might get back out of the arangement. I am still waiting to see if Carver comes up with better prices.
   / Replacing B2400 3pt sway links w/B27/2910 links #5
I did it to my B7500. The dealer swapped my brand-new turnbuckles for the telescoping bars for peanuts. They are a lot easier to use than the turnbuckles. The holes are unevenly spaced in the inside bar, and that makes them almost infinitely adjustable. If you decide for some reason you want the attachment to be 4" to the right or left, just lift it off the ground, pop the pins, swing it over and replace the pins......................chim
Thanks for the info. I had been thinking about this ever since I saw the new links, but I finally got the nudge when my turnbuckle threads got stripped. With the telescoping link design, it seems the worst thing that could happen is elongation of the adjustment holes (replacing the adjustment pins seems pretty minor).
Thanks!
Rick
   / Replacing B2400 3pt sway links w/B27/2910 links #7
Chim,
You wouldnt happen to have the parts #s for them would you.
___________________________________________
Take care, Jim
   / Replacing B2400 3pt sway links w/B27/2910 links #8
I'd be happy to give you the numbers if I could locate them. Unfortunately I can't find the slip. The dealer looked them up on the computer and ordered the parts, and swapped me for my brand new turnbuckle type plus $50. I think he told me the parts listed for around $120 if I would have just bought them straight out. It was an easy swap - just note that the shaft they mount to on the tractor end has a setscrew with a dimple in the middle that needs loosened so you can slide it left and right. At least that's how my 7500 is. Sorry I can't be of more help...............chim
   / Replacing B2400 3pt sway links w/B27/2910 links #9
Chim,
Thanks for the quick reply, Im going to head down and see what my dealer can do for me cause it sure would be a lot easier than them turnbuckles and cotter pins.
____________________________________________
Take care, Jim
   / Replacing B2400 3pt sway links w/B27/2910 links #10
Here's the parts list and prices that I have when I switched a couple of years ago.
This numbers are entered in neat columns, but when I post them, they show up without the linefeeds. Sorry about the mess!
Qty. Part # Price (for 1)
4 04011-50120 .20
2 05122-51235 1.35
2 05122-61245 1.35
4 05511-50425 .20
2 05515-61000 1.30
2 60070-65320 13.65
2 60070-65340 1.20
2 60070-65330 13.65
2 60070-65350 1.31
2 60070-65310 26.68
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
Brushfox XHD-72 (A53421)
Brushfox XHD-72...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
