Replacing a B&S Vanguard engine on lawn/garden tractor
   / Replacing a B&S Vanguard engine on lawn/garden tractor #1
Carl in CT
Lebanon, CT
1958 Massey Harris Ferguson 202 loader/backhoe
Not sure but my 23hp Vanguard engine might be blown. I should know more when the shop gets a chance to look at it but it has little to no compression. I want to explore options now even though I am holding out hope it isn't actually blown. The mechanic who has it now isn't a fan of replacing engines with anything except the exact same model. Sure, that's a lot easier but this is a $1,400 engine and I'd like to explore cheaper options. It is a 4 or 5 year old Briggs Vanguard 23hp engine. The numbers are as follows:
Engine model: 386777
Type: 0111-G1
Code: 08012611
Model # 386777-0111
23.0 HP
Commercial power
Vertical Crankshaft
Vanguard Series
OVERHEAD VALVE DESIGN (O.H.V.) design
"V" Twin Cylinder
Cast Iron Sleeve
12 Volt Electric Start
16 Amp Alternator
1 Dia. x 3-5/32 Crankshaft. PLEASE make sure you compare your engine crankshaft size with this Crankshaft size or call us.
Full 1/4" keyway
Crankshaft is drilled and tapped ready for bolt 7/16-20
Equipped for Remote
Has Oil Filter
Has Oil Cooler
Has Fuel Pump
I realize that things like mufflers and wiring harnesses will be different and could present a challenge but if I can find an engine (new or used) with the same crankshaft size/specs how hard is it really to make a different engine work?
   / Replacing a B&S Vanguard engine on lawn/garden tractor #2
My Vanguards have been very good engines... I like them and would buy another...
IF, I was you, I'd rebuild what you have or replace it with another Vanguard.
SR
   / Replacing a B&S Vanguard engine on lawn/garden tractor #3
Smallenginewarehouse.com has 2 models of the 386777 with 1" cranks for $995 plus shipping(and every thing else on your list)
   / Replacing a B&S Vanguard engine on lawn/garden tractor #4
On my budget, I'd consider a Predator.
22 HP (78cc) V-Twin Vertical Shaft Gas Engine EPA
Can't swear it's a total drop-in for what you need, but I'd find a way to make it work.... sometimes that's less work than convincing a mechanic to install something he doesn't want to.... :)
Not that I'm anti-Briggs (all the sizeable air-cooled motors I own are Briggs) but unless that was commercial-use/high hours, I'd wonder why the original motor was done that quickly....
Rgds, D.
(Edit - first thing I'd check is rotation direction)
   / Replacing a B&S Vanguard engine on lawn/garden tractor #5
Wish they had a 13hp vertical.
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
2015 Kia Sedona Van (A51694)
2015 Kia Sedona...
2008 Ford F-450 SD 4WD Pickup Truck (A53117)
2008 Ford F-450 SD...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
