Replacement Tires
/ Replacement Tires #1
BSLMS
Upstate NY
Yanmar 424
I am soon going to need to replace the front tires on my 7254. Currently has Carlisle Turf Pro 23x9.5-12 mounted. I can't seem to find that tire anywhere. I can find Turf Masters in that size, is there any reason that those cannot be substituted? I use Turf Masters on my commercial lawn equipment with good results. Will that tire work on my tractor that has a FEL? I would choose the 4-ply construction.
/ Replacement Tires #2
Check the load capacity of your present tire and compare it to the Turf Masters. If it is the same then they should be fine.
/ Replacement Tires
Thanks, Cori. I was thinking that would be the determining factor.
