Replacement Tires
   / Replacement Tires #1
BSLMS
Upstate NY
Yanmar 424
I am soon going to need to replace the front tires on my 7254. Currently has Carlisle Turf Pro 23x9.5-12 mounted. I can't seem to find that tire anywhere. I can find Turf Masters in that size, is there any reason that those cannot be substituted? I use Turf Masters on my commercial lawn equipment with good results. Will that tire work on my tractor that has a FEL? I would choose the 4-ply construction.
   / Replacement Tires #2
Check the load capacity of your present tire and compare it to the Turf Masters. If it is the same then they should be fine.
   / Replacement Tires
Thanks, Cori. I was thinking that would be the determining factor.
Vermeer V800 (A50324)
New Idea Manure Spreader (A50515)
New Idea Manure...
Gator XUV560S4 (A50324)
Gator XUV560S4...
2006 International 9400i (A52128)
2006 International...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
ATLAS 10 1/2' DISC HARROW (A51243)
ATLAS 10 1/2' DISC...
