Replacement Tires and Wheels for MX5100
   / Replacement Tires and Wheels for MX5100 #1
Poopdeck Pappy
Elite Member
Dallas, Texas
Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
I'd appreciate any tips you guys have on finding replacement wheels and tires (R4 or R1) for an MX5100. I'm looking at one that has turfs on it, and I would want to replace them with R4s or R1s (preferably R4s). Front and rear, of course.
I know I can order them from Kubota, but I haven't knocked over any banks lately so I hope there may be other sources.
Also, is there any market for the used turf tires that would come off of it? They are in great shape. Just not sure how many people out there are looking for turf tires for a utility tractor of that size.
   / Replacement Tires and Wheels for MX5100 #2
Here's a salvage outfit that sells used and aftermarket parts online... they might have or help find the correct rims. There are probably many others; this is just one I found on the web.
Tractor Rims: Rims || Weaver's Compact Tractor Parts & Compact Tractor Salvage
There should be any number of tire suppliers within 100 miles of DFW that do agricultural tires. If your loot will cover it, they'd certainly have new stuff, maybe even a rims + tires deal.
That's probably not much more than you already knew... maybe someone else has more ideas.
   / Replacement Tires and Wheels for MX5100 #3
I would be interested in the turf tires if they would fit on my L5740. I may even be interested in swapping. I have R4's on mine. And the front's are new.
Grandad, thanks for the tip.
CompleteLawnCare, I'd be interested in that trade if this deal on the MX works out. The tire sizes on the MX5100 and the L5740 are the same except that the front R4's on the MX are 12" wide while the ones on the L5740 are 10" wide (according to Kubota's website). That should work, but I'd want to check with Kubota to make sure. That difference is interesting because the turf tires are exactly the same on both tractors according to Kubota's website. I'd also want to check out the bolt pattern and axle size on both tractors.
   / Replacement Tires and Wheels for MX5100 #5
I saw that the tires are the same size. But, we would need to confirm the bolt pattern. Let me know if you make the deal on the 5100, then maybe we can make a deal too.
My brother has a 5100, and I could compare his to my L5740.
   / Replacement Tires and Wheels for MX5100 #6
Did you ever make the deal on the 5100? I'm still interested in the turf tires.
If not, could you give me the name of the dealer that has the turf tires?
Sorry for the late reply. No, I did not make the deal on the 5100. It was a private seller selling one with turf tires on it.
   / Replacement Tires and Wheels for MX5100 #8
Okay....thanks anyway.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
