Replacement Thermostat for DK40SE
   / Replacement Thermostat for DK40SE #1
kattywumpus
Southern Maine
Kioti DK40SE with Cab.
Anyone know what the thermostat part number is for DK40SE? Is this something I can get at NAPA? No cab heat looks like the thermostat stuck open.
   / Replacement Thermostat for DK40SE #2
here you go..
E5853-73011 THERMOSTAT ASSY $21.95
I looked it up here.
OEM Parts
   / Replacement Thermostat for DK40SE #3
thermostat#E5800-73011 gasket#E5500-73272 Feel the top hose to see if coolant is get thru. Does the temp gauge go up?
Yes, the temp gauge does go up after several minutes. My guess is the engine reaches operating temperature after 20 or 30 minutes, but no hot coolant is getting to the cab heater.
   / Replacement Thermostat for DK40SE #5
is it possible you have an air bubble in the heater hoses?..
   / Replacement Thermostat for DK40SE #6
How does one get a air bubble out of a heater hose? I've done lots of car work and have never run into this. Is this a tractor thing?
Anything possible. I did think of that but since the engine normally doesn't take long to reach operating temperature and its a lot easier to change the thermostat then open the cab roof I figured I try changing the thermostat first.
   / Replacement Thermostat for DK40SE #8
I have seen several posts on this. I suppose kinda like vapor lock.. apparently it can happen. I will see what I can find.
   / Replacement Thermostat for DK40SE #10
Now I got it, Cause the heater core is mounted so high up the water pump must have a hard time moving it. Where as a car its like 6 inches higher than the pump. Am always learning. katty, have you been in the cooling system lately?
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
5ft Rotary Tiller (A51573)
5ft Rotary Tiller...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
