Replacement Snow Plow Cylinders - Quality vs $$ ??
   / Replacement Snow Plow Cylinders - Quality vs $$ ?? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I want to replace the badly leaking angle cylinders on my old Fisher plow. A quick check shows a Fisher branded part for $120, Buyer's OEM part for $90, and RCMP replacement part for $76. All have identical specs. Having no experience with replacement cylinders, is there much difference between these quality wise ?? Thanks
gg
   / Replacement Snow Plow Cylinders - Quality vs $$ ?? #2
I'd go for best price as in all probability they will outlast your old Fisher anyway.
I'd suspect the main difference is the OEM mark up anyway, even the possibility exists that they purchase them from the same low price supplier.
OK, makes sense. I just thought it would be prudent to ask. Thank you very much.
gg
   / Replacement Snow Plow Cylinders - Quality vs $$ ?? #4
Sometimes you get what you pay for. Sometimes a cheap tool ends up costing twice as much when you realize it doesnt perform.
I guess that's the question. Could say some times the expensive one is junk right out of the box ??? Just looking for someone to say don't buy the cheap cylinder. They are junk. But I have not heard that yet.
gg
   / Replacement Snow Plow Cylinders - Quality vs $$ ?? #6
i bent one of the angle cylinders on my 10' plow and replaced it with a cheap one at least 10 years ago. The replacement is still working just fine. It doesn't see any salt though. Maybe if it did rust could be an issue.
   / Replacement Snow Plow Cylinders - Quality vs $$ ?? #7
gg
It's hard to tell these days with most component manufacturing being outsourced now to China and India. For all you know the OEM and aftermarket parts come out of the same factory. Problem is that some of the knock off junk is such poor quality you are losing money just by considering it.
   / Replacement Snow Plow Cylinders - Quality vs $$ ?? #8
Why not rebuild your old cylinders if they are just leaky?
   / Replacement Snow Plow Cylinders - Quality vs $$ ?? #9
Buyers is a pretty common replacement part supplier, and builds their own plows. The other company I've never heard of. If it were me, I'd go with the Buyers.
   / Replacement Snow Plow Cylinders - Quality vs $$ ?? #10
Actually, I rebuild plow cyls routinely. The worse ones I’ve seen are the new OEM fisher rams. Many years ago Fisher used rams built by Monarch Hydraulics Grand Rapids, MI. The OEM Monarch rams had k-wipers and v-packing seals and lasted almost forever if the rams were greased/oiled during the off-season to ward off rusty chrome.
The new Fisher rams are just a thin AN wiper and one single poly seal and many come in with a cracked gland. Some of the off brand cylinders have the v-packing style but it would be almost impossible to tell without taking apart due to the copycat nature of all these Chinese imports coming in.
If the rods are not pitted with corrosion, and the gland nuts are not rusted too tight it would be worth rebuilding the existing rams.
12in Backhoe Bucket (A52748)
12in Backhoe...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
2019 Kenworth T680 Tandem Axle Road Tractor (A47384)
2019 Kenworth T680...
Case 580D (A47384)
Case 580D (A47384)
Ditch Witch 350Sx Tractor (A50322)
Ditch Witch 350Sx...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
