Replacement seat for Kioti ds4510hs
   / Replacement seat for Kioti ds4510hs #1
kev0rkian
Susanville, CA
Kioti DS4510HS
New guy here. Just bought a used 2013 ds4510hs. I really like it so far, but the seat has brittle, cracked vinyl. Looks like the Kioti replacement costs more than $500, which is a little more than I would like to spend. I'm wondering if I can buy an aftermarket TSC replacement "universal" seat that would work. Has anyone here replaced their seat on this or a similar Kioti tractor?
   / Replacement seat for Kioti ds4510hs #2
I put a seat with armrests from TSC on my DK 35 years ago.
Its a nice seat.
I think it did take some slight modifications to fit. Can't remember what it was.
   / Replacement seat for Kioti ds4510hs #3
Mine is a 2006 and I noticed for the first time a few days ago a little area with tiny cracks developing. I nearly cried and rang the police and fire department but no-one cared....:rolleyes:
I thought, well, you are now 9 years old so I should expect this I guess. Still disappointing when it is kept in a shed all the time. I think some upholsterers will recover them, however they are not quite the same.
   / Replacement seat for Kioti ds4510hs #4
My original seat is still fine.
I wanted arm rest is the reason I replaced the seat.
   / Replacement seat for Kioti ds4510hs #5
Tractor Supply Company sells seats. I have a fabric cover pulled over mine which also has handy pockets in the back. Don't know where the wife bought it (some catalog)
   / Replacement seat for Kioti ds4510hs #6
My 2006 DK has many seat cracks and splits, back ribbing coming off. Foam rubber does as intended by capturing/retaining water until you sit upon it. One of the TSC models (I can not recall which one but it had arms), did not fit very well. Once I got it installed by re-drilling some mounting holes, I found I was too close to the steering steering wheel even with slider arrangement fully to the rear. I am now back to original but use a deer hunter foam seat pad, mainly as they do not absorb water.
Thanks for all the replies. I'll probably buy a generic tractor seat cover as a starting point.
2018 Chevrolet Silverado (A56858)
2018 Chevrolet...
2024 RAM 3500 CAB & CHASSIS (A59575)
2024 RAM 3500 CAB...
2015 Freightliner M2 106 AWD Terex Commander 4047 Digger Derrick Truck (A55973)
2015 Freightliner...
Kubota Tractor NR (A56857)
Kubota Tractor NR...
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
