Replacement joystick boot for a FEL?
   / Replacement joystick boot for a FEL? #1
MrWhippy
Maryland
Ford 1710, Ford 5600, NH Workmaster 55
So there's a long tear in the rubber boot for the joystick. I was just going to order a new one, but the OEM boot is $40 some dollars. Seems pretty darn high. Is there a less expensive alternative, like a generic joystick rubber boot that people use?
A square boot would be a better fit. I'm looking at Woods boots ($10-15) that are square shaped. Not sure size-wise however...
   / Replacement joystick boot for a FEL? #5
This was a great idea. I searched square GEARSHIFT boots and found several reasonably priced options. Thanks!
The only concern I would have is that the gearshift boots may not have UV protection like a boot designed to be on a tractor. However, I don't know that the rubber tractor boots are made any different. For the difference in price, it's worth a try.
   / Replacement joystick boot for a FEL? #6
I found a miniature sink plunger at Tractor Supply on sale for $1.99. I cut off the handle the plunger and it fit the joystick lever just right. Not perfect, but inexpensive way to keep control valves out of the weather. DSCN6902.jpgA photo is attached.
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2013 FORD F-350 (INOPERABLE) (A58214)
2013 FORD F-350...
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2014 CATERPILLAR...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
