Mike_S
Every 3-4 years the four hydraulic connector covers and plugs for the FEL on my JD 4400HST must be replaced because they harden up and become impossible to use. The female side of the four couplers is a royal PITA to take loose from the bracket in order to slide the tail loops of the POS JD OEM hydraulic connector covers on and then remount the four couplers into the bracket. These are slightly smaller than standard tractor hydraulic connector covers/plugs and it is EXTREMELY difficult to get the wrench onto the securing fasteners due to the small space between the female hydraulic connectors in the bracket.
This time I would love to avoid going through that nightmare -- are there any hydraulic connector covers/plugs that fit my tractor which have tails that "snap on" the hydraulic lines so that the female connectors do NOT have to be removed from the bracket that holds them -- OR is there another solution??
Thanks (kindly forgive crossposting to the JD Owning and Operating forum since this may be a JD-only scenario)
Mike_S
Mike_S
