Replacement hood for BX2350
   / Replacement hood for BX2350 #1
derecskey
Has anyone with a BX2350, BX23, BX24, etc replaced their plastic hood with a metal hood from the BX25, BX2660? I was in at my local dealer (Middlefield Farm and Garden) and they had the 2660 inside and the 2350 sitting out in the field. I took a good look and a few measurements and it sure as heck seems like the metal hood would fit the BX2350.
I am pretty sure the hood dimensions and shape are identical. I think the headlight housing may be the same shape as well. The latch position is the same. The only thing I could see that was different was where the lift arm/gas shock connect the metal version has 2 more bolts, meaning you might have to replace the lift arm piece as well.
Any thoughts? If I was a dealer, I'd try this out when I had 2 machines in the shop just to see if it works and figure I could probably move a lot of steel hoods!
My plastic hood is pretty busted up due to a mishap with a spring loaded log (I saw my life flash before my eyes). I'm not ready to replace it yet, but if and when I do, I want to go steel if that is an option.
   / Replacement hood for BX2350 #2
This has been brought up quite a few times without any conclusion. I agree with you that if it were interchangeable that there would be quite a few people interested in the metal hood. I have looked at both and feel that it would be possible, but have not had the two next to each other.
   / Replacement hood for BX2350 #3
flatlander said it already. it been brought up before, but nobody had the guts to try for real. I even threw it out a message to a online kubota dealer to see if they could check it out for us. No go.:( I have the plastic hood too and its not cracked yet :rolleyes: but scratched up, but I am curious about the appearance of new metal hood with old plastic fenders,floorboard. I would really like to know if this is an option for me in the future if I ever have a mishap with hood. It may or not ever happen, but options are nice.
I'm pretty sure the BX2660 at my dealer had a metal hood and plastic front side panel (uni-fender?)
   / Replacement hood for BX2350 #7
I do know first hand that the panel cover (plastic panel with wire mesh screen that sets under the dash panel, covering the battery, etc... Does integrate. The newer model features two metal support brackets with nuts & bolts that draws the plastic panel frame tighter.
prior to this fix, my panel would vibrate loose and became a major issue. the fix looks good, frame is tight, ridged and seems much more likely to last
decided to upgrade after my bird dog ripped the panel off, chewed all the wiring (yes all of it) to find a mouse under the hood.
i spent all day today soldering 20 gauge wires, everything works but the headlights now. for the life of me i cant' figure out where this one orange/brown wire goes. Apparently they only sell the entire wiring harness @ $220
the dog DID eat my homework
   / Replacement hood for BX2350 #8
THANK YOU!! gwdemos!!! I just purchased the new and improver cover when mine cracked. The new one STILL bows out...and now I know why. I did not see those supports underthe BX24 parts manual but I see them under the BX2660 parts manual. I just put the upper and lower on order!!!
Deano
   / Replacement hood for BX2350 #9
Deano
Dean - Now it makes sense on why my newer BX24 doesn't have the same problem as yours does. Looking at yours last weekend, I couldn't see what was different and didn't notice that I have supports to prevent the problem with it bowing out.
   / Replacement hood for BX2350 #10
Had a BX2350 and traded it for a BX2660 and had nothing to do with the difference in hoods. My BX2660 metal hood now has a dent in it from the tree limb, if it was plastic it would probably not have caused any damage. To me the difference is the tighter fit at the rear bottom of the metal hood vs the plastic hood.
2003 John Deere 2210 Compact Tractor (RUNS) (A50774)
2003 John Deere...
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
378741 (A51572)
378741 (A51572)
2012 Dodge Grand Caravan Van (A50324)
2012 Dodge Grand...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
KJ 8'x6' Powder Coated Steel Site Fence (A50121)
KJ 8'x6' Powder...
