Replacement fuel tank shutoff valves?
   / Replacement fuel tank shutoff valves? #1
timb
Southwest PA
Deere 4710/reverser, JD 318 (still needs TLC), JD LT160
Anyone know if the small shutoff valves typically located under the gravity-feed fuel tanks of lawn tractors, tillers, snowblowers and the like are pretty generic/universal? I need to replace one on an old Troy-Bilt tiller (the 'wing nut' just spins in place). I've found one site selling a 'universal' unit for 1/8" NPT tank threads and 1/4" fuel line that sounds about right but I didn't know if there were a lot of hidden variants. Any recommendations for a gasoline-compatible thread sealing compound to use on the tank threads?
Thanks
Tim
   / Replacement fuel tank shutoff valves? #2
timb,
I can't imagine that there would be much difference. As long as the flow rate (inputs/outputs) are the same as the one you have it should do the job.
2021 Harley-Davidson FLHP Police Electra Glide Motorcycle (A51694)
2021...
2016 E-Z Beever M12R Towable Brush Chipper (A51692)
2016 E-Z Beever...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
