Replacement fuel tank shutoff valves?
   / Replacement fuel tank shutoff valves? #1
timb
Veteran Member
Southwest PA
Deere 4710/reverser, JD 318 (still needs TLC), JD LT160
Anyone know if the small shutoff valves typically located under the gravity-feed fuel tanks of lawn tractors, tillers, snowblowers and the like are pretty generic/universal? I need to replace one on an old Troy-Bilt tiller (the 'wing nut' just spins in place). I've found one site selling a 'universal' unit for 1/8" NPT tank threads and 1/4" fuel line that sounds about right but I didn't know if there were a lot of hidden variants. Any recommendations for a gasoline-compatible thread sealing compound to use on the tank threads?
Tim
   / Replacement fuel tank shutoff valves? #2
timb,
I can't imagine that there would be much difference. As long as the flow rate (inputs/outputs) are the same as the one you have it should do the job.
PAIR OF FRAME MOUNTS FOR VACUUM PUMPS (A53843)
PAIR OF FRAME...
2017 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2017 DRAGON...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2015 CHEVROLET C3500 SERVICE TRUCK (A51406)
2015 CHEVROLET...
