replacement for 325
/ replacement for 325 #1
buckthorn
Black Earth, WI
New Holland TC33D, John Deere x590, John Deere 325, Kubota RTV 900
We've had a JD 325 for 13 years (~1000 hours) with a 54-inch deck, and have had more and more problems for the past 2-3 years. Nothing major in terms of components failing, but it's been one thing after another, and usually when we need it most: failed engine seal, replace oil filter housing, replace oil pressure sensor, replace idler arm assembly in the mowing deck....
So we're thinking that it's time that we bite the bullet and buy a new unit. And I'm looking for recommendations. Here's how we use the tractor:
- "regular" lawn mowing (uneven ground, sometime wet, heavy grass, slopes, ~2-3 acres. We don't really care about having a beautiful lawn; we just want to keep it from getting too long. We use a mulching kit so we don't have to pick up a ton of grass.
- mowing rows of 6-year-old tree plantings (uneven ground, slopes, taller grass and sometimes thick weeds, often wet). The plantings are roughly 12 acres, but we don't mow every row as the trees and shrubs have started to fill some rows in.
- mow some trails and paths, some in the woods, others similar to the tree row mowing
- rototill a 2500-foot vegetable garden, usually twice a year
Most of the work is now spent mowing the tree rows. We are sometimes out there for 2-3 hours at a time in mid-summer. The conditions are pretty tough: either it's hot and dusty, or it's cool and rather wet, all of which must make the tractor work pretty hard. Above all we need something that's sturdy and heavy-duty (not to mention easy to maintain and trouble-free); I'd say that the 325 has probably been at the top edge of its mowing capabilities and capacity, especially since we put in those tree plantings. It's done a beautiful job with tilling the garden; it would be nice to keep that rototiller, but I fear that it is incompatible with the newer tractors. We could possibly move down to a 48-inch deck; I'm not sure that the 54 is all that beneficial, and it makes the tractor work even harder.
So which models do people recommend for us to look at? We also have a New Holland T33D to handle the larger brushcutting jobs and maintaining our gravel driveway, so I think we want to stick with something in the lawn and garden category.
/ replacement for 325 #2
Sounds to me like you are about 2 series to small on the duties you are tasking the 325 with.
You may want to consider something in the BX kubota/JD 2000 series.
Not that your 325 isn't up to the task, these bigger machines are just better suited and should last longer/do a better job.
/ replacement for 325 #3
I'm sorry to say that you will have a very tough time these days finding something in the lawn, and garden category that will work as well as your 325 has. I used a JD 345 briefly on my 3+ acres of yard, and I think that was about twice the tractor that the new X500 series is, and that is too bad. I'm kinda looking too, and I just haven't found anything yet. Probably the Simplicity Prestige is the closest these days, but that is a 7K tractor too, and I have kind of a love / hate relationship with the full width roller on the back of their mower decks. I'm afraid you might have to bite a tougher bullet than you had thought these days.
/ replacement for 325 #4
An X540 would be my recommendation if you want to stay in the L & G series. I want one really bad...
/ replacement for 325 #5
not 100% sure, but believe the old 325-355(GX) series attachements will still link up to the x500 series, although the new X500 series also lists the new attachments as well. Go to "Build Your Own" on JD's website and you will see what I mean. It shows both sets of attachments. your dealer should be able to clarify.
/ replacement for 325 #6
Unfortunately they won't. I have a 1996 345 and my father has a 2007 X540. Our attachments are not interchangeable.
/ replacement for 325 #7
Thats a bummer. I have a 325 with a blower, blade, tiller & mower. No way i can afford to buy all those attachments again. The thing I hate about the 325 is that I cant mount three attachments at once. My 112, 212 & 214 allow front, mid and rear attachments simultaneously.
Covington TP-66 (A64127)
Covington TP-66...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
Coleman Powermate Generator (A62613)
Coleman Powermate...
2016 Dodge Ram 5500 (A64127)
2016 Dodge Ram...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
KMC 4505 (A64126)
KMC 4505 (A64126)
