Tiller Replacement discs for disc tiller
   / Replacement discs for disc tiller #1
CECILSSTEEL
Lower Alabama
I need to replace the discs on a 1950's Krause disc tiller (single axle 4 disc plow). The disc tiller requires 26 in disc with a 4.5 inch concavity which is higher than the 3.5 inch standard concavity used on harrow discs of this diameter.
Who would be able to supply this type replacement disc or any suggestions on who to contact?
Thanks
   / Replacement discs for disc tiller #2
Thanks
JD did use a deeper dish blade than some others. You may wish to try Agri Supply (they have stores in the Carolinas and Georgia, internet sales, catalog and phone help. You should have no problem finding them on the internet.
Thanks for the input. By good fortune was able to obtain three plow disc blades 26in ellipical 4-1/8 concavity blades from a nearby implement dealer in Lucedale, MS that nearly duplicates the original. Will reuse the fourth blade. This will should get the disc tiller up and going for now.
Have contacted Agri Supply as an option.
Krause has also helped in locating 26in ellipical blades 4-1/4 in concavity in their stock.
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
Informational Lot - Financing (A56435)
Informational Lot...
2016 FREIGHTLINER CASCADIA SLEEPER (A57880)
2016 FREIGHTLINER...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
2015 GMC 3500 HD 4x4 Crew Cab Pickup truck (A55973)
2015 GMC 3500 HD...
