Replacement discharge chute for 60" MMM?
   / Replacement discharge chute for 60" MMM? #1
Buster57
Platinum Member
Hillsboro, Oregon
B7800, JD RX95
I just received delivery of my new B7800 with 60” MMM.
The problem I can foresee is the discharge chute is metal. Plastic is better.
The discharge chute on the MMM on the BX1850 was plastic. It worked great. I think the 60” is excellent but I know I am going to tear that discharge chute up. I have done this on every mower deck I have ever owned that had a metal not plastic chute.
Is there a replacement plastic chute available? Does anyone have any suggestions?
Thanks!
   / Replacement discharge chute for 60" MMM? #2
My suggestion is to take it off. I did that on my 60" MMM because it interfered with the vacuum hose when I have it on. I don't have any rocks in my lawn so launching missles is not an issue. With the chute removed you can trim on the right side as well as the left. Just my .02. I am sure someone while slam me for the safety issue but I can take it. Good luck.
   / Replacement discharge chute for 60" MMM? #3
Thanks!
Why are you tearing them up?
   / Replacement discharge chute for 60" MMM? #4
I'm with RaT - what is the problem? I mounted a hydraulic motor on my deck so that I can raise and lower the flap on the fly.
   / Replacement discharge chute for 60" MMM? #5
People tend to get used to things being a certain way. I have a metal discharge shoot on my BX2200 and am happy with it. I may be wrong but I think that Kubota has gone to plastic discharge shoots on their small tractor decks as a cost saving measure...just like the plastic fenders and hood. If metal is unfavorable then why is it used on the larger commercial tractor decks that you see out there every day?????
   / Replacement discharge chute for 60" MMM? #6
I keep mine bungie'd up 98% of the time. It disburses the clippings better this way and it allows me to do some triming on the right side too as well as fitting around some tight spaces better.
I'd remove it but after 3 seasons I'm kinda used to it being there. It's metal but it wouldn't matter to me if'n it was plastic as I'd still just bungie it up :D
   / Replacement discharge chute for 60" MMM? #7
""""ATTENTION SAFETY POLICE"""""" :eek:
:p
A nice bullet proof plastic that could be run over by a semi and still retain its original form would be nice.
   / Replacement discharge chute for 60" MMM? #8
:eek: :D
2025 Swict 84in Bucket Skid Steer Attachment (A55787)
2025 Swict 84in...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
20pc 4ft. x 3ft. Black Metal Diamond Plate (A55758)
20pc 4ft. x 3ft...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
