replaced head gasket now has a miss
   / replaced head gasket now has a miss #1
snikers01
2003 new holland tc 33
I have a tc33 that I just replaced the head gasket. Got it started and now has a bit of a miss. Will start and run but low on power . I do have a injector that has a slight leak going to replace all of the copper washers this week. Could it be that injector sucking air or what else? I looked everthing over the head was decked and inspected by machine shop.Now idles very low but doesnt stall like at 750 rpm?
   / replaced head gasket now has a miss #2
Did you adjust the valve lash & position per spec after reinstalling the head?
I found one of my fuel lines at the pump was not fully tightened and it was sucking air. Valve lash was checked. I still have my over heating problem though.
   / replaced head gasket now has a miss #4
Water pump? May be time for a replacement.
Have you checked that you are getting the full stated amount of coolant into and out of the system? (Maybe you have a blockage?)
Worst case, maybe a cracked block? Does the coolant appear to be building too much pressure?
Not sure about the water pump its not leaking are the propeller plastic? Did not see any cracks in the block. Going to pull rad and send it to rad shop.
   / replaced head gasket now has a miss #6
I missed some of the earlier post on overheating of your tractor. Could you explain how you came to that conclusion? Temp gauge,etc.
I have a tc33d, have owned it from new, I have to clean radiator and oil cooler frequently to keep temp gauge out of the red. Usually use power washer and simple green to clean fins out.
boils over easy anytime mowing. i also power wash rad but pulled it out yesterday and it was very dirty on the fan side with oil and crude build up and backed on grass. Rad shop will boil it. So i am pretty sure that is my problem. From the outside it looked clean!
   / replaced head gasket now has a miss #8
Let us know if that resolves the problem.
the radiator cleaning did the trick gauge sits in the middle of the first green block. Even runs a bit better not being so hot. I wish I would of done this sooner
   / replaced head gasket now has a miss #10
That is great news. I was thinking of doing that on mine also, now you convinced me to get it done.
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
2003 Komatsu WA250 Articulated Wheel Loader (A50322)
2003 Komatsu WA250...
Silo Auger (A50121)
Silo Auger (A50121)
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2013 BMW X5 xDrive50i AWD SUV (A50324)
2013 BMW X5...
