Oil & Fuel Replaced BX Fuel Tank
/ Replaced BX Fuel Tank #1
JonSpinosa
Baldwinsville, New York
With that big snow storm heading to the northeast, I thought I should stop procrastinating and replace the infamous leaky BX fuel tank I have had in my garage for 3 months. I just figured that would be the time to start leaking just when the tractor was most needed! Isn't that the way things go? It took me about an hour to change it.
I was wondering if any of you guys changed your tank? My tractor was one year old and did not have any problems. After looking over the old tank and new tank, there is not any difference. The only difference with the field recall kit is the mounting bracket. If you guys see the old mounting bracket and the new bracket, you can not help but wonder what is the advantage or improvement of the new kit.
After close scrutiny of the two designs, I am just as concerned now with a leaky fuel tank with the new tank as the old. What does anyone else think who is familiar with the two designs?
/ Replaced BX Fuel Tank #2
Never saw the brackets (dealer performed the work), and my tank was leaking at the time. From what I was told, the old design allowed the tank to rub against some metal during vibrations. The metal would eventually cut through the plastic tank. When it was returned, the mechanic showed me where to look, pointing out that some spacers/cushions were added to the new design. Did one of your brackets have cushions, the other not?
Roy,
The old design had a steel spacer between the tank and frame. The new design also uses a spacer, the difference being that the spacer is attached to a bracket that mounts to the frame. There are no cushions of any type. Fundamentally, I just cannot see the big improvement!
/ Replaced BX Fuel Tank #4
Jon, were you able to just pickup the tank at your dealer?
del
/ Replaced BX Fuel Tank #5
Jon; Since it's been a while since the work was performed (last summer), I am doing this by memory (known to be fallible /w3tcompact/icons/frown.gif). What the mechanic may of said was 'a spacer to cushion'. Don't think I had 40 hours on it at the time that I sprung the leak. Ever since the service was performed, no problems to date (112 hours). I am guilty of being a little rough with my tractor, lots of hard 'banging and bouncing' (but that's what I bought it for, to work). So, it doesn't surprise me that since the original design problem was movement-related, I had experienced the leak.
Maybe it's simply that with excessive vibrations, the old spacer would fall-off. They may of simply moved it to the bracket itself to achieve a better bond.
/ Replaced BX Fuel Tank #6
Why did you change your own fuel tank? Your dealer was supposed to take care of everything. Warranty covered all aspects including pickup and delivery. This was a full recall. Just curious as to how you ended up changing it yourself.
Hi guys,
I purchased the BX tractor out of state so the dealer shipped me the fuel tank kit and he also sent me the updated 3 point kit at the same time. I am about 250 miles away from the dealer and thought it would be easier and faster if I did it. The dealer was very good about shipping me the recall parts.
Jon
/ Replaced BX Fuel Tank #8
I just replaced my leaking tank. The old tank had a hole cut in it so chips could be removed, then a plug welded in the hole. This is where the leak occured, probably helped by the tight mount which stresses the plastic. The new tank is solid even though it still has a mold seam where the hole was in the old tank. The new bracket lets the tank float. The arrow shows the hairline crack in the weld.
/ Replaced BX Fuel Tank #9
I thought I'd resurrect this post that I found in a search. My tank is leaking too! It seems to be coming from the top left (if seated) side and from the way it is flowing down the tank I think it is leaking at the mold seam.
What is this stuff about a recall? What are the SN#s of the recall. I hate to loose my tractor now that I am a FEL junkie!
Can anyone fill me in on the history and details of the failure and recall?
Rogue
Roque, That is exactly the location of the fuel tank. I am not sure of the serial numbers effected, however, it seems to be a moot point since it sounds like the fuel tank is leaking by your description. If you call your dealer, I am sure he can change the tank for you or ship you a new tank. I changed my own tank, it took me about 45 minutes.
Jon.
/ Replaced BX Fuel Tank #11
I recently bought a grey B7001 and I assume Kubota still use similar technology. The guy in the local spare parts dealer said they are selling alot of plastic tanks in Aust. People leave the tractor in the sun with a half full tank. Damage from the suns radiation and heat/pressure build up split the tanks down the seam. - solution - Keep tank full of diesel and don't leave tractor in the sun. Fades the paintwork anyway. I get the feeling that these tanks have a limited life span and are not UV stabilised plastic.
/ Replaced BX Fuel Tank #13
When I had the '95 B7100, the fuel tank sprung a leak at the bottom, where one of the two metal bands went around it. That happened when it was about 3 years old and had 300+ hours on it, and it was always stored inside.
Bird
/ Replaced BX Fuel Tank #14
Saturday night pondering:
Couldn't this whole tank be replaced with some 1/4" nylon tees
and a couple small lengths of hose?
We're all in this together! (3)
Retired Yuppie Tractor Owner
/ Replaced BX Fuel Tank #15
Roque, I have had my BX tank replaced due to the nipple connected to a fuel hose being cracked on the left rear side. Another place to look is the fuel sender on the upper left side. It may not have been sealed properly and may need a new gasket/sealer (yet another first hand experiance with the new tank).
The dealer should be able to fix or replace the tank at your house in an hour or less.
/ Replaced BX Fuel Tank #16
I really hope they will do it at my house. Such a pain to have it get shipped out and banged up. I will check my SN# when I go to the house today.
Rogue
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
2008 HEARTLAND RV CYCLONE 40 FOOT TOY HAULER (A59914)
2008 HEARTLAND RV...
2017 Ford Fusion SE (A64557)
2017 Ford Fusion...
GREAT PLAINS TURBO-MAX 1200 - 12' VERTICAL TILLAGE (A64277)
GREAT PLAINS...
1500 gal Poly Tank (A66408)
1500 gal Poly Tank...
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
