replace top link with hydraulic cylinder ??
   / replace top link with hydraulic cylinder ?? #1
rothmans
Hi
I have MF50 Gas tractor.
It has two hydraulic valve control levers located behind the gear shift.
one lever is not in use.
Could I replace the top link of the 3 point hitch with a hydraulic cylinder ??
thanks
   / replace top link with hydraulic cylinder ?? #2
Sure, you can do that...and many have! Do a search for the term "ccm", it's a company that sells one with a built in check valve to keep it from drifting. You can also search the term "htl" (hydraulic top link) and "DPOCV"(dual pilot operated check valve) Surplus Center also has them.
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
2006 MACK CV713 KILL TRUCK (A52472)
2006 MACK CV713...
2015 PETERBILT 389 (A52472)
2015 PETERBILT 389...
