drajj5
Going from 1.5 ton to 2 ton on an 1100sq ft apartment I wouldnt consider oversized.
And the contamination from previous compressor failure is what this hvac guy is suspecting too.
I am just wondering about the price. Does 2650 seem reasonable for that 2-ton unit installed with new inside coil?
OR should I shop around for someone willing to install a lesser quality (perhaps), 1.5 ton unit?
Not too concerned about seer rating. They are efficient and well insulated apartments. And I do not pay the electric bill. So I will see no savings of a higher eff unit
LD1, I just had a heat pump installed at the house I am renting out- just last week. I was quoted 3,100.00 and that was for a entire new air handler and outdoor compressor/condenser unit. This home had gas heat only and conditioned 1150sqft. The unit they installed was a Goodman branded unit both inside and out. The boys that came out and did the install were top notch and had to run all of the lineset under the house and plumb a drain. Brand new Honeywell T-stat and new thermostat wire were pulled as well (10 wire was needed).
But..... I chose to remove gas from the equation due to the added stress from wondering if they (tenants) are keeping the tank full and not running a bunch of space heaters in the winter vs. buying gas for heat.
I did spend above the amount I just quoted as I installed the new electrical breakers and ran supply power to the inside air handler (heat strips) and to the outside unit disconnect. It added another 350 to the cost of the new A/C.
Now I need to figure out how to use the super fancy digital t-stat...
Hope this gives you some insight via my experience.
Gafn is spot on with regard to oversizing a unit. Most tenants will run the **** out of central heat and air so you should be good with a 2ton unit. People in the winter are cold at 70, however will set the t-stat at 64 during the summer months and crank it up to 80 in the winter. Renters are hard on stuff, I rented a car once..... but that's another story:devil:
