Replace my 30 year old Ford 1520 4WD compact with new Kioti CK2610H ?
   / Replace my 30 year old Ford 1520 4WD compact with new Kioti CK2610H ? #31
   / Replace my 30 year old Ford 1520 4WD compact with new Kioti CK2610H ? #32
The 35hp tractor will only consume more fuel if it is doing more work. If you work it at the same rate as the 26 hp tractor, fuel consumption will be pretty close to the same.
Fuel consumed is power delivered x bsfc, ie both tractors will have about the same brake specific fuel consumption, measured in pounds of fuel burned pee horsepower-hour of power delivered, but the higher powered tractor can deliver more horsepower. If you don稚 ask the tractor to deliver that higher horsepower, by doing more work, then it won稚 burn any more fuel than the lower horsepower tractor.
Belly up and get the factory cab with air. You won稚 regret it.
   / Replace my 30 year old Ford 1520 4WD compact with new Kioti CK2610H ? #33
If you keep the condenser somewhat clean, a tractor ac should freeze you out when ambient temp is less than 100f. I only run mine on high for the first few minutes when I get in, then I start having to turn it down even when its in the 90s.
2016 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2016 Ram 1500 4x4...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
Oil Well Pump Jack with Motor (A49461)
Oil Well Pump Jack...
2012 PETERBILT 386 (A50854)
2012 PETERBILT 386...
2016 CAT 289D SKIDSTEER (A50854)
2016 CAT 289D...
