Replace Kohler Motor in Grasshopper
   / Replace Kohler Motor in Grasshopper #1
fresno99
Duncan, OK
Cub Cadet 7264
I have a 1998 grasshopper that had a Kohler Command 20 hp motor on it. The motor blew a hole in the side, not for sure if it had been repaired at one time or not I bought it used. I have found what is supposed to be a 2004 Cub mower that has a Kohler Command 23 hp motor on it. Should I be able to just swapped these motors out? My grasshopper machine is in pretty good shape and the cub is not but the motor is supposed to be. Thanks for any input.
   / Replace Kohler Motor in Grasshopper #2
Check on the bolt pattern for mounting the motor and check on the bolt pattern for mounting anything to the shaft of the motor and check on the diameter and length of the shaft as well.
   / Replace Kohler Motor in Grasshopper #3
Looks like you can buy a used Kohler Command 20 hp replacement engine block for $100 from eBay vendor. Other parts also listed there.
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53473)
UNVERFERTH 330 8...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
