Replace fan belt on B7100
   / Replace fan belt on B7100 #1
SGBotsford
Near Edmonton, Alberta
Deuzt 6250 + Kubota 7100
I needed:
Metric socket set.
Needle nose pliers.
WD 40
#2 phillips screwdriver
Helps: cordless impact wrench or drill.
Adapter to put sockets on wrench/drill.
A: Remove left panel. Held on with a bunch of 8 mm hex head phillips screw (It's a bolt head with a phillips star) and 2 12 mm bolts.
B: Remove hood. The hinge bolts have pins. Remove with needle nose. If you don't notice this the bolts are very hard to remove.
C: Radiator is held by two bolts under the bottom edge. Also pinned. I was able to get the left one undone. The right one remains stubborn.
D: Remove the 4 phillips head screws that hold the fan shroud.
E: Loosen the bolt in the centre of the adjustment pulley.
F: Unscrew adjustment screw. On mine this just came out instead of pushing the pulley carrier. Tap with hammer.
At this point I could swing the left edge of the radiator forward about an inch.
G: With several skinned knuckles I worked the new belt over two of the blades of the fan, then passed the the other side of the belt over the front face of the fan. Combination of turning the fan, tweaking with finger tips, and holding my tongue in the corner of my mouth. Fortunately my dogs are tolerant of my language.
Drive pulley on engine has a spline protruding from the front. A plate is in front of this. Remove plate. 2 more 10 mm bolts.
Put belt over drive pulley, then adjustment pulley. Tighten adjustment pulley. Tighten center nut of pulley.
Reverse the assembly.
My respect for Kubota declined over this. This is an aggravating amount of work for a common repair.
   / Replace fan belt on B7100 #2
Replaced belt on my B2710 a couple of years back. Think all I had to do was pop off the side panels, had alternator off for bearing replacement (also reason for belt replacement) worked belt onto the fan blades and slowly rotated the blade till had old belt off and did reverse to get new belt over fan blade to pulley. Installed belt on to the fan pulley, alternator pulley after the crankshaft pulley. Tighten the belt, tighten the alternator bolts, snapped back on side panels.Think I used combo wrenches only. Sure big difference between the two. That is a lot of difference between the two models to me. My M6800 is even easier, no side panels.
   / Replace fan belt on B7100 #3
And that's one of the reason call compact....with loader on twice as much fun. :confused2:
MAHINDRA EMAX 225 TRACTOR (A51243)
MAHINDRA EMAX 225...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
Kubota L503OD 50HP Utility Loader Tractor (A50322)
Kubota L503OD 50HP...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
Vermeer SC802 (A50322)
