Replace Coupler bushing to hydraulic pump
/ Replace Coupler bushing to hydraulic pump #1
duke7595
S/W MO.
820 ,1520,1020 (D) 1020 (G) 1050,4020 2240
Anyone have experience replacing the coupler bushings that drives the hydraulic pump (front) on a 2240 John Deere? Such as where I can purchase and the part number? Thank you..
/ Replace Coupler bushing to hydraulic pump #2
Due to the fact that a JD 2240 could have 2 different type frt hyd pump drive couplers one needs to know yr model or tractor serial # of tractor in question to give correct answer. If your tractor has the drive with 4 bushings then unbolt drive clamps,cut old bushings off of drive studs,apply liquid shop to new bushings(part # R45822) & push onto studs then reinstall halves of clamp . R45822 can be purchased at JD dealer or just perform a Google search utilizing PN.
Thanks Jim for replying, yes it is the 4 bushing coupler and the part# is correct for this model. This was the initial problem learning the proper part# seems there are a few out there that will not work even with the correct serial number, John Deere appeared to use different couplers according to what was on hand.. Also, I'm not familiar with this repair so I wanted some verification from someone with experience .. Thanks again.
/ Replace Coupler bushing to hydraulic pump #4
Put a new belt on it while your at it. The bushings aren't that bad to replace.
Yes sir will differently put a new belt on.. Thank you Jim.
/ Replace Coupler bushing to hydraulic pump #6
Although over the yrs there have been other part numbers(AR34098 OR AR49427) that have been substituted that refer to these bushings I don't remember any that were different size. I was employed at a JD dealership from '66-'87 spending part of my tenor working in parts department.
Correct, the number you gave me is the one referred to below.. The price of $2.12 a piece is not bad as well. Thanks again Jim..
Bushing, Hydraulic Drive for John Deere 2240 Tractors
PART #: R45822
This product is available for purchase in increments of 4 only.
Price: $2.12
/ Replace Coupler bushing to hydraulic pump #8
It's ironic but my local JD dealer conglomerate wants $3.63 for the very same bushing
BTW You're welcome,Jim
Jim it seems John Deere parts, especially from a dealer are higher, however, I'm happy with the price considering the cost of many other parts..Take care and God bless...
BTW These parts came from "Tractor Joe" 1-888-860-9096
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2018 Ford Escape SE SUV (A64557)
2018 Ford Escape...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
