Due to the fact that a JD 2240 could have 2 different type frt hyd pump drive couplers one needs to know yr model or tractor serial # of tractor in question to give correct answer. If your tractor has the drive with 4 bushings then unbolt drive clamps,cut old bushings off of drive studs,apply liquid shop to new bushings(part # R45822) & push onto studs then reinstall halves of clamp . R45822 can be purchased at JD dealer or just perform a Google search utilizing PN.
Correct, the number you gave me is the one referred to below.. The price of $2.12 a piece is not bad as well. Thanks again Jim..Although over the yrs there have been other part numbers(AR34098 OR AR49427) that have been substituted that refer to these bushings I don't remember any that were different size. I was employed at a JD dealership from '66-'87 spending part of my tenor working in parts department.
It's ironic but my local JD dealer conglomerate wants $3.63 for the very same bushing
BTW You're welcome,Jim
