Replace All 4 tires or just fronts?
   / Replace All 4 tires or just fronts? #1
RandyinMS
Ashland, MS
Farmall Cub
Hello needing some advice
I have an LS Tractor XR4150 HST with over 2,000 hours. It is a 4wd which I use a lot. The front tires are splitting. The rears are in pretty good shape. Can I buy/replace just the fronts? My mind is telling me that because of the 4wd I have to buy 4 new tires. My budget is hoping for just fronts.
Will replacing just fronts mess with thew 4wd gearing?
TIA
Randy
   / Replace All 4 tires or just fronts? #2
Go till they blow.
You should be able to replace the fronts (of the same size as the existing) with no qualms.
   / Replace All 4 tires or just fronts? #3
You can replace the front tires alone as long as the replacement front tires are the same diameter.
If you have a Loader on your tractor, replace the front tires sooner rather than later.
   / Replace All 4 tires or just fronts? #4
I replaced front only on my Branson for same reason you are looking. I didn’t want one blowing out when had loader full and raised.
Go with same size should not be a problem
   / Replace All 4 tires or just fronts? #5
That's pretty common. Replace the fronts. Then you can think about the rears later. Mechanically replacing the front - with OEM type tires - nwill also help get the lead/lag ratio closer to right again. I suspect it is getting hard to shift OUT of 4wd with a load in the bucket.
   / Replace All 4 tires or just fronts? #6
I replaced just the fronts on mine many years ago and did not have any problems with the 4wd.
   / Replace All 4 tires or just fronts? #7
Just the fronts just make sure they are the same size.
   / Replace All 4 tires or just fronts? #9
Yeah, I hear you. I did the same with one of mine and had no problem either - which was surprising, but happens. Since small tractors are 4wd assist instead of full time 4wd, they depend a lot on tire shape & size for how the 4wd works. Tire wear and FEL load changes the tire shape and that changes the front/rear gear ratio. Sometimes that makes it hard to shift out of 4wd. Not always....
Apologies for repeating what so many owners already know, but we have a lot of new tractor owners on TBN.
Enjoy,
rScotty
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2017 Kubota K008-3 Mini Excavator (A54865)
2017 Kubota K008-3...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
72" QUICK ATTACH BUCKET **DAMAGED** (A52706)
72" QUICK ATTACH...
Cat TH407C Telehandler (A53472)
Cat TH407C...
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
