Repairing/upgrading RV garage door
   / Repairing/upgrading RV garage door #11
I've got an RV shed with about a 12x14 sectional garage door on tracks.
When I bought the place ~ 12 years ago it was manual. No helper springs or motors. For all these years I've just lifted it up and put a 9' piece of 1x6 to hold it up. I'd spray the rollers with garage door lube when it stuck and it worked for me. Probably only opened it 50 times a year at the most,
Well, due to the expanding universe it's gotten heavier. I'd like to put on helper springs or a motor if they were affordable. Less than $500 and DIY.
Any suggestions?
if you are looking for a diy solution that easier than the spring fix a simple counter weight system on both corners is cheap and easy and relatively safe to concoct.
seems like you have been making out fine w/o so not much assist needed.
(15) UNUSED IRANCH 94"X41" FLOOR PROTECTION MATS (A58376)
(15) UNUSED IRANCH...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2022 Delta Gooseneck Equipment Trailer VIN # 4MWGF4022PN059238 (A57453)
2022 Delta...
20(10) UNUSED SDLANCH 2.5CM X 3.5M RATCHET STRAPS (A58375)
20(10) UNUSED...
2023 FORD F-250 STX (A58214)
2023 FORD F-250...
