Repairing a bent rim
/ Repairing a bent rim #1
Whitnel
Lebanon, TN
Kubota GL3240
It appears I have a bent center section on the tractor I just bought:mad:. The rim will vary from 1 3/4" to 3/4" from a fixed point on the tractor. It gets within 1/2" of the fender.
I believe the center section is bent in. I can see a discoloration on the center section and with a level I can see a difference between the two side of the from the center.
Left side just behine the lug nuts
Can just the center section of the rim be replaced and fix this problem? Or will both pieces need to be replaced?
/ Repairing a bent rim #2
Sure you didn't bend the axle? I have to ask how you bent it to evaluate the axle itself.
Proper and recommended procedure is to replace the entire wheel assembly plus the capscrews that affix the rim to the hub because they have been compromised with stress.
I have no idea how it happened. I just bought it Saturday and did not notice it until Sunday. The axle assembly still looks good to me. No cracks, broken seals or leaks. The tractor did have a bent fender, I am guessing when this happened the rim damage happened as well.
I send the pictures to Brady at Barlows (where I bought the tractor) this morning. I think they are going to work with me on getting this fixed. I was OK with a bent fender but bent axle or rim would have had to be fixed.
/ Repairing a bent rim #4
Looks like someone took a long skid down an icy hill into a curb, a hop off a trailer, or some other kind of bad trip. Sorry to hear about your misfortune. Hope your dealer helps out - let us know.
-Jim
/ Repairing a bent rim #5
In my experience using tractors, those wheels can take quite a bit of stress. I would think you'd know what did it, if you bent it. Just driving around, even on bumpy ground, wouldn't cause that. I'm thinking it happened before you purchased the tractor.
You are correct, it was like this when I bought it just did not know it. When driving around Barlow's lot it was not noticable.
First thing I did when I got it to my property was run down the road to borrow a rotary cutter. The guy following me stopped me to tell me something was wrong. I could feel it when driving but thought it was just how tractor rode.
I sent these pictures to Brady with Barlow's yesterday. I am going to follow up with them today to see if they are going to help me get this fixed. It sucks to have bought a tractor and be really excited then find out something like this. I just hope nothing else is messed up and is still hiding from me.
/ Repairing a bent rim #7
swap the wheels left to right and see if the wobble goes or stays. You could do the same with the center spider, too. Could it be that the wheel is just not on the pilot square?
The actual center section is bent in towards the tractor in one place. So that will have to be replaced. I checked to make sure the rim was pulled up even and tight to the axle assembly.
I just wonder if the outside part needs to be replaced as well, I would think it would but have never messed with a tractor tire before.
/ Repairing a bent rim #9
I bought a 1976 F250 brand new. While driving it home from the dealer I was stopped by a trooper to tell me my rear wheel was about to fall off. The wheel was not loose was not bent but had been welded crooked, it was a split rim. Check to see if the hub portion is correct.
/ Repairing a bent rim #10
mark the close spot on the tire.
mark the rim and hub
take the wheel off move it 2 or 3 holes on the hub reassemble it and see if the close spot is in the same place on tire as first marked
If not axle is most likely at fault not the rim.
or swap the tires side to side to see of problem moves.
Just got an email from Brady with Barlows. They are sending me a new center section. Hopefully this will fix this issue.
/ Repairing a bent rim #12
-Jim
Exactly ... or something precisely similar. The center section should fix it. - If not completely there may be a little rim twist or axle tweak. If it comes down to 3/8" or so I wouldnt worry about it a speeds below 40mph.
larry
Dropped my tractor off at the dealership yesterday for service. Just turned over 300 hours. Time for an oil change and told them to do the filters as well. Don't know the tractors history so figured it was worth it. They are going to change out the center section of the rim while it is there. I did not feel like doing it in the middle of a field, don't have a shop or garage to work in yet. Hope to get it back soon.
/ Repairing a bent rim #14
You might want to keep the old center. It can be straightened, or used for metal stock to construct stuf. Probably at least a $10 value even as scrap.
larry
Good idea, I am sure I can figure out something to do with it.
Got the new center put on. Tire runs good and straight now.
/ Repairing a bent rim #17
How well did Barlows treat you? You said they were going to work with you, just wondering how well that worked out.
Worked out good. When I contacted them about the bent rim they had the replacement one to me within a few days. It just took me a few weeks to switch them out.
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
Skid Steer Bale Spear (A65640)
Skid Steer Bale...
Cattle Feeder (A65640)
11in. Bucket w/ Teeth Excavator Attachment (A64194)
11in. Bucket w/...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
