Whitnel
Gold Member
It appears I have a bent center section on the tractor I just bought
. The rim will vary from 1 3/4" to 3/4" from a fixed point on the tractor. It gets within 1/2" of the fender.
I believe the center section is bent in. I can see a discoloration on the center section and with a level I can see a difference between the two side of the from the center.
Left side just behine the lug nuts
Can just the center section of the rim be replaced and fix this problem? Or will both pieces need to be replaced?
