repair pto drive shaft
   / repair pto drive shaft #1
emery
Western Mass
Kubota b9200
I have a shortenned 3pt drive shaft that I want to lengthen for use with other implement. Does anyone have any experience with lengthening the slip shaft?
I'm told you should separate at universal and weld in piece there the slip of the shaft would not occur when using implement.
Will this work?
   / repair pto drive shaft #2
<font color=blue>...I have a shortenned 3pt drive shaft that I want to lengthen for use with other implement. ..</font color=blue>
That kinda sounds like cutting your floor joists too short in your house... and then gluing the ends together to make longer..../w3tcompact/icons/frown.gif
No...I wouldn't weld it to lengthen... very dangerous under torque/load conditions... can break and fly apart...
To weld a stationary piece is one thing... not a PTO shaft though...
And yes people have done it and gotten by... only with a prayer... It's a very serious accident waiting to happen... /w3tcompact/icons/crazy.gif
   / repair pto drive shaft #3
I agree with John, it would probably work, and if the welder's good enough, it might not break, but it's a chance I wouldn't take.
   / repair pto drive shaft #4
Emery,
Well, two very knowledgeable guys have given you good advice. When I have visions of flying metal and think about 540 PTO speed, the price of a new shaft doesn’t seem much. Now that I have chipped in my 2 cents it will even be cheaper./w3tcompact/icons/smile.gif
MarkV
   / repair pto drive shaft #5
Personally, I wouldn't weld a 'piece' in to lengthen it, but I sure would have a competent machinist cut the yokes or ends off and retube it! Been there, done that...to include drive shafts on many different types of vehicles.
Be sure if you do retube it, that the shaft is balanced. The welding is half of the equation, the other half is the balancing of the finished shaft.
<P ID="edit"><FONT SIZE=-1>Edited by scruffy on 11/30/01 03:39 PM (server time).</FONT></P>
Ok, I get the message about the danger and will heed the good advice. Thanks.
Anyone got a URL for finding a new tube? My type is not rectangular, but sort of a triangle cross section.
Thanks again for the advice.
   / repair pto drive shaft #8
Emery, if all you need is a few inches (...and who amongst us doesn't?/w3tcompact/icons/wink.gif) you can find a PTO shaft extension in the 2001 Tractor Suppy catalog on page 204. I have a chipper/shredder that I have to use an extension on one tractor without an overrun clutch and not use it on a tractor with the overrun clutch. The difference is about 2-1/2" to 3". ...hope this helps.
JimI<P ID="edit"><FONT SIZE=-1>Edited by jinman on 12/01/01 07:01 AM (server time).</FONT></P>
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
2023 RHINO X1406 LOT IDENTIFIER 74 (A53084)
2023 RHINO X1406...
2014 GMC Sierra (A51692)
2014 GMC Sierra...
Fire Truck (A51692)
Fire Truck (A51692)
2018 Kia Soul Crossover SUV (A51694)
2018 Kia Soul...
