repair or scrap??
/ repair or scrap?? #1
goaliedad
NORTHWEST MICHIGAN
KUBOTA L175
I have a Kubota L175 that no longer likes reverse. I pulled the top plate off the tranny hoping to find a bad gear selector. I think it is the gear that's bad. I no longer need the tractor. My question is do I have it repaired then sell it, or scrap it out? If I decide to scrap it, are there any dealers that may be interested? any ideas?
Thanks guys
/ repair or scrap?? #2
Thanks guys
I'd sell it...if the transmission goes into the forward gears and all else works.
/ repair or scrap?? #3
Not sure what it costs to have it fixed, but I gurantee it's cheaper then buying a new tractor. Is it paid for? I'd fix it and keep using it.
Good luck,
Eddie
/ repair or scrap??
Eddie- I agree that fixing it would make sense- if I was going to need a tractor. We have moved closer to town and I no longer need a tractor- we have a much shorter driveway now.
I think I will put it in the paper and see what kind of response I get. Any more ideas are welcome.
Other than the reverse issue it has been a pretty good tractor- front mounted snow blower, loaded turf tires with chains, 3pt works- never used the pto.
/ repair or scrap?? #5
You might try craig's list as well. Doesn't cost anything.
/ repair or scrap?? #6
See if there is a school near you that needs a project for the shop class. They could tear down, repair, repaint, then you could sell or let them auction it off to raise money. Just an idea.
/ repair or scrap?? #7
i think I'd find a cheap used gear for it, and learn how to rebuild a tractor trans... and call it a fun experience..
Soundguy
/ repair or scrap?? #8
Soundguy
I agree. Tractor transmissions are pretty simple. The only "odd" tool you need is a press to push the gears / bearings off of some shafts.
The only critical item is setting preload when going back together.
jb
/ repair or scrap?? #9
Thanks guys
I need to see a picture before I can make a call like this.
Albeit, I'd find a used tranny and swap them out. I did this recently on a small JD 170. Most of the small trannys are the same.
2023 Kubota SVL97-2 Compact Track Loader (A63118)
2023 Kubota...
40' 6 Door Shipping Container (A60352)
40' 6 Door...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
HYSTER H80XL STRAIGHT MAST FORKLIFT (A62129)
HYSTER H80XL...
New/Unused 13,000lb Electric Winch (A61166)
New/Unused...
