Repair of LMT
   / Repair of LMT #11
Well since it's bending I like your idea of adding bars to it @ponytug . As far as material, buckets seem to either fatigue out (crack) or wear through (abrasion-related holes). For fatigue, usually you want a moderate carbon steel like a 1040 and some strategically placed plates or bars. The goal is to make the cross-sectional area larger so the same force has to act across a larger area.
For abrasion you can either switch to a hardenable steel (1065 or higher carbon) OR add a sacrificial bolt-on section that you replace regularly (like the bucket design at the bottom of the pics I posted yesterday). The challenge is that hard steel isn't tough steel, so you can wind up trading one problem for the other. This is why the sacrificial bolt-ons make sense for some applications.
Speaking of sacrificial material, this reminds me I need to track down some rubber to replace the bottom of my blade next season. I went with the rubber bottom on it so it wouldn't dig into my driveway when I scrape it clean, but that does mean ya gotta replace the rubber when you've had your fun. 😉
   / Repair of LMT #12
@BigDaddyEureka Thanks! Wear isn't my problem yet, just the bending. I do have fairly hard soils when dry, and often back drag to get enough down pressure with a good cutting angle for good soil cutting. Hard spots bend the back blade. I will try to find a 1040 1/4" or 3/8" bar and weld it on to see how it goes. I will probably reinforce the bucket sides at the same time so as not to trade one problem for another...
All the best,
Peter
CFG Industry MX12RX Mini Excavator (A57149)
CFG Industry...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
John Deere 6135E 4WD 135HP Agricultural Tractor (A56857)
John Deere 6135E...
2025 LandHonor RB-14-66W 66in Rock Bucket Skid Steer Attachment (A56857)
2025 LandHonor...
2009 BMW X3 Sport AWD SUV (A56859)
2009 BMW X3 Sport...
