Repair of LMT
   / Repair of LMT #1
RegL
Platinum Member
Northwestern CT
PT 1430
Anyone had to repair their light materials bucket. I know it will involve welding but wondering best way to reinforce the area.
   / Repair of LMT #2
Mine is still practically new, but we make these kinds of repairs on wheel loader buckets all the time.
A basic patch on the outside and a fillet weld on the inside should do I'd think.
   / Repair of LMT #3
How many hours of abuse did it take to get that way, I only say abuse, as most of us push our machines beyond the stated limits. Just curious so I know about when mine is going to fail.
I agree, patch and fillet weld. At least you caught it before you had to bend it back into shape first.
   / Repair of LMT
Abusing that one since 2003. Thanks for the advice.
   / Repair of LMT #5
I would be inclined to do as the others suggested above, and in addition patch the side as well as the underside to strengthen the corner weld. Whatever you did/do is applying more force than the lip edge can handle. You might consider a flat bar of high strength steel welded on just behind the existing edge, or cut out the existing edge and top in a high strength edge that is wider, and reinforce the existing vertical edge.
You could also out YouTube where the are a number of lip repairs to buckets for ideas.
All the best,
Peter
   / Repair of LMT #7
With this past weekends 20" snow, and my bucket catching on rocks and roots, this was all I could think about.
   / Repair of LMT #8
Here is a nice video of a somewhat larger bucket repair 😉;
Cutting Edge Engineering: CAT 330 Bucket Repair
Kurtis does some amazingly high quality hand welding, setting up the pieces so that he gets full penetration welds for maximum strength. Many of his welds look like they were robotically done. What I enjoy about his videos is that he has a real understanding of how heavy equipment will be used, and how repairs can make an item weaker or stronger, and what the tradeoffs may be. The BIS80 steel he mentions is an Australian low carbon, high strength steel, which may be close to A-656 steel. (I am no steel expert.)
All the best,
Peter
   / Repair of LMT #10
@BigDaddyEureka Yes, those are quite the machines (and buckets!).:)
As you seem to be an expert, for those of use with bent buckets, any recommendations on what material to use to replace the skin with something a little stronger and more durable? I have a running battle with the floor of my 4N1 bucket, which is always bending. More wear bars of? New skin made of? New cutting edges made of? I have no problems welding things together. I am just at a bit of a loss on what would be a reasonable path forward.
All the best,
Peter
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52748)
2021 John Deere...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
