Repair for cub 7275
/ Repair for cub 7275 #1
rims421
Eastern CT
new holland tc- 35
I have recently purchased a Cub 7275 with a FEL . I have added a 3 point hitch backhoe from my last tractor ( mits 210d) I am having trouble getting grease into the fittings on the FEL any ideas? Also getting ready to sell the Mits tractor.
I purchased the tractor with the hoe on it ( never used the 3 point hitch) the control arms were replaced with some "custom made " sections of steel I would like to set the tractor 3 point hitch back up for resale Any ideas where I could find control arms for this tractor?
/ Repair for cub 7275 #2
Have you tried removing the fittings and cleaning them? The fitings on my Cub are a little worn and you really have to exert some effort to keep the hose on the fitting while you pump the grease gun.
I ended up removing most of the fittings, backing out the pins, cleaning the hole out, and reinstalling new fittings.
A lot of work but at least i managed to get grease to flow into the pins like it should. I had a tough time with the bottom fitting of the backhoe ( side to side movement) but finally succeded by heating it up good with the torch.
iDrive TDS-2010H...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2012 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
